2005 Kia Sportage
jlwz71
Member - Posts: 9
Posted: August 06, 2005 at 9:22 PM / IP Logged
Looking for a wiring diagram for this vehicle. 2005 Kia Sportage with power windows and locks. Looking to put keyless entry with remote start on it. I think I saw also that is may have a passlock style security. Any help would be great. Thanks.
dare_ds69
Silver - Posts: 419
Posted: August 08, 2005 at 6:10 AM / IP Logged
here you go
12volts white (30A), red (30A)  +  ignition harness
Starter green  +  ignition harness
Second Starter N/A
Ignition blue  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory pink  +  ignition harness
Keysense WHITE/ orange  +  ign harn or ETACM, 22P plug, pin 10
Notes: The ETACM (Electronic Time and Alarm Control Module) is in the center console, behind the radio and heater control opening.
Power Lock green  -  DKP or ETACM, 26 pin plug, pin 19
Power Unlock blue  -  DKP or ETACM, 26 pin plug, pin 21
To unlock the driver door only, use gray/orange (-) at the ETACM, 26 pin plug, pin 25.
Lock Motor red  5wi driver kick, door harness
Unlock Motor green  5wi driver kick, door harness
Parking Lights+ green (L), green (R)  +  back of fuse box, 18 pin plug
Parking Lights- brown  -  sw. or ETACM, 22 pin plug, pin 8
Hazards ORANGE / black  -  ETACM, 26 pin plug, pin 10
Turn Signal(L) blue  +  turn signal switch
Turn Signal(R) green  +  turn signal switch
Reverse Light white  +  back of fuse box, 18 pin plug
Door Trigger orange  -  DKP or ETACM, 22 pin plug, pin 13
Dome Supervision brown  -  ETACM, 26 pin pug, pin 1
Trunk/Hatch Pin blue  -  DKP or ETACM, 22 pin plug, pin 14
Hood Pin white  -  sw. or ETACM, 22 pin plug, pin 15
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue  ac  cluster, 20 pin plug, pin 19 or ECM
Notes: The ECM (Engine Control Module) is on the driver side firewall, under the hood.
On the 2.0L, the tach wire is in pin 66.
On the 2.7L, the tach wire is in the 40 pin plug, pin 17.
Can also go to any fuel injector and use the wire that is NOT white.
Wait to start N/A
Brake Wire red  +  brake pedal switch
Parking Brake blue/orange  -  sw. or ETACM, 22 pin plug, pin 17
Horn Trigger blue  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2005 Kia Sportage -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
how own your mind, control your life.
MECP certified. always use a DMM
jlwz71
Member - Posts: 9
Posted: August 09, 2005 at 10:09 PM / IP Logged
Thank you very much.
