Relocating DEI 520T, 2003 TLS
NYDesi80
Member - Posts: 26
Posted: August 08, 2005 at 10:44 PM / IP Logged
I own a 2003 TLS equipped with Clifford 3.5, DEI 530T modules, DEI 506T, and DEI 520T.  I would like to relocate the DEI 520T (back up battery module) and need some quick help.
If I unplug the DEI 520T will i set off the alarm?  Somone told me that when I unplug it, it wont' go off, but when I plug it back into the brain then it will go off.  Is this true?
If it does will simply pushing the unlock button on the key fob disengate it?
What is the proper way to do this?
I know this should be very easy for some of you so if you could just quikcly tell me I'd be greatful.
Thank You
dare_ds69
Silver - Posts: 419
Posted: August 09, 2005 at 6:13 AM / IP Logged
the best way is put the alarm in valet mode and do it.
how own your mind, control your life.
MECP certified. always use a DMM
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
