94 jeep grand cherokee factory alarm?
mutt69
Member - Posts: 8
Posted: August 16, 2005 at 7:58 PM / IP Logged
Hi guys great forum,the best i've seen.
my dilmema is I bought my wife a 94 jeep grand cherokee limited w/factory alarm an can't find a wiring diagram for the alram system.I have a viper 791xv that i want to take the place of the factory system. Any help or tips would be greatly appreciated.thank you in advance
        Randy
Live loud and fast or die slow and silent.        Noize Pollution C.C
swamprat323
Gold - Posts: 1,335
Posted: August 16, 2005 at 8:03 PM / IP Logged
just leave the factory alarm alone. just use the factory arm/disram wires.
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|pink/blk or RED / wht |+ |steering column             |
|          STARTER|yellow/blue (small) |+ |steering column             |
|        IGNITION|blue/gray           |+ |steering column             |
|        ACCESSORY|ORANGE / black        |+ |steering column             |
|       POWER LOCK|ORANGE / purple       |+ |blk conn. drivers kick      |
|     POWER UNLOCK|pink/purple        |+ |or red conn. pass kick      |
| PARKING LIGHTS +|blue/red            |   |left of st. column          |
|       HEADLIGHTS|tan/black           |+ |at switch-high and low      |
|     DOOR TRIGGER|yellow *2           |- |drivers kick panel          |
| TRUNK/HATCH PIN|tied in with doors |- |drivers kick panel          |
|        HOOD PIN|BROWN / tan           |- |pass. kick blue plug        |
| FCTRY ALARM ARM|pink/orange        |+ |pass. kick red plug        |
|FCTRY ALRM DISARM|purple / YELLOW       |- |driver kick black plug      |
|       TACHOMETER|gray/blue           |   |pcm *1                      |
|       BRAKE WIRE|white               |+ |left of brake pedal        |
|     HORN TRIGGER|gray/orange        |- |steering column             |
|           WIPERS|BROWN / white        |+ |steering column             |
| LF WINDOW UP/DN|white - lt. blue    |A |drivers window switch       |
| RF WINDOW UP/DN|brn/wht - pur/wht   |A |drivers switch or kick panel|
| LR WINDOW UP/DN|blu/wht - RED / blk   |A |drivers switch or kick panel|
| RR WINDOW UP/DN|gry/blk - grn/wht   |A |drivers switch or kick panel|
Notes:
*1 High on passenger side firewall under hood. *2 Not underdash light
mutt69
Member - Posts: 8
Posted: August 17, 2005 at 6:50 AM / IP Logged
thanks for the info i realy appreciate it
offroadzj
Gold - Posts: 2,043
Posted: August 17, 2005 at 9:55 PM / IP Logged
im not saying this is what you should do, but here is what i did:
When i bought the jeep (94 Grand Laredo) it had a non-factory installed factory alarm. The wires were a complete nightmare. You couldnt even replace the brake switch bc there was just a mass of random wires. So i found the 2 starter wires, and completely removed the factory alarm and tossed it in the trash. Everything works great, and when i installed my python 881xp, i made sure to make everything a lot neater.
Kenny
mad_max555
Posted: August 24, 2005 at 10:41 PM / IP Logged
Hi,
I just bought a used 94 cherokee laredo and it works pretty good but the guy we bought it from didn't give us the owners manual and when I locked it up last night I hit the lock button on the drivers side  and then shut the door and then I noticed I had left a window open so I went to open it and put the key in the drivers side door and the security system went off which is the only way I know that it has a security system.  Well anyways it has a controller on the keys but it's really crappy and it dosen't work, so can someone tell me about this security system and how the heck I can turn It off so I can acctually open the door and have it not go off, and how to turn it off when it does go off.  any help would be greatly appreciated.
offroadzj
Gold - Posts: 2,043
Posted: August 25, 2005 at 12:37 AM / IP Logged
well it looks as if the person bought a factory alarm, but didnt have it installed by the factory. If it was installed by the factory, then it was a really crappy job.
Kenny
mutt69
Member - Posts: 8
Posted: August 26, 2005 at 10:56 AM / IP Logged
hi
on mine the factory remote was broke when i bought mine.all it was,was the button fell of the board just had to soider them back on.also the power lock an unlock switches arm an dis arm the system if the onlock relay isn'y working them the only way to disarm the system is w/the remote
good luck   randy
mutt69
Member - Posts: 8
Posted: August 26, 2005 at 12:06 PM / IP Logged
sorry been up too long (solder)
95xjsport
Member - Posts: 9
Posted: September 04, 2005 at 10:58 PM / IP Logged
where is the factory alarm? I am in the process of installing a keyless entry in a 93 grand cherokee limited. becuase I don't have the remotes, and they are more than I can spend to replace. I have an aftermarket system that I took out of my brothers volvo after he totalled it...
Platinum - Posts: 12,488
Posted: September 05, 2005 at 8:09 AM / IP Logged
To permanently disarm teh OEM security system all you have to do is ground the purple / YELLOW wire located at the driver kick panel in a black plug.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
