ford escape 03 door locks
stereotornado
Member - Posts: 10
Posted: August 21, 2005 at 7:19 PM / IP Logged
l have a ford escape 2003 and in the door locks says the it's only 1 wire and it's negative, that needs a 1000 ohm resistor and it has to use ralay does anybody know how to do it. any diagram so l can know how to do it
thanks
mo12v
Posted: August 21, 2005 at 7:32 PM / IP Logged
2 SPDT RELAYS:
LOCK:
PIN 87 = Ground
PIN 30 = 1K Ohm Resistor to Vehicles PINK/White wire
PIN 85 = Negative Lock Output from RS/Alarm
PIN 86 = Constant 12 volt ( + )
UNLOCK:
PIN 87 = Ground
PIN 30 = to Vehicles PINK/White wire
PIN 85 = Negative UNLock Output from RS/Alarm
OR
Power LockLT GREEN/ BLACK **DRIVERS KICK PANEL
Power UnlockWHITE/ VIOLETDRIVERS KICK PANEL
Negative Pulse Door Lock
MO
