installing remote start on '01 stratus
Intrepid
Member - Posts: 35
Posted: December 04, 2002 at 3:56 PM / IP Logged
i'm about to install a remote stater on my stratus, and i've got all the main wiring down(power, ground, door sens., brake) but how do i find the tech wire? and also does anyone have the wiring diagram for that stratus?
thanks,
securinu
Silver - Posts: 772
Posted: December 04, 2002 at 9:38 PM / IP Logged
sedan or coupe???
securinu
Silver - Posts: 772
Posted: December 04, 2002 at 9:39 PM / IP Logged
Car Wire Profile for 2001 Dodge Stratus Sedan
 Wire ColorLocationInstructions
StarterYL.IGNITION..
Notes:
1. This circuit is fused at 40 amps, the RD is fused at 20 amps. 2. One wire activation, 620 ohms for lock, 2700 ohms for unlock. 3. Located in 22 pin C5 conn of B.C.M., Arm in pin 10, Diarm in pin 4 and Unlock Sense in pin 3. 4. Arm requires a 750 ohm resistor and diarm requires 1.8k ohm resistor. 5. The factory keyless antenna are in pin 3 and 4 of the C4 conn of the B.C.M. 6. This vehicle is Transponder equipped.
T-Harness Info
Starter Disable/Power: .
Door Lock: ..
Complete Alarm Harness: .
Remote Start: .
Factory Keyless Upgrade: .
Technical Bulletins Related to this vehicle:
Constant 12VPK/BLK.IGNITION.1.
Switched 12VD.BLU.IGNITION..
Dome LightYL.U.F.B.N.
Parking LightsBLK/YL.S.C..P.
HornBLK/RD.S.C..N.
Door LockWHT/D.GRN.B.C.M..P/2.
Door UnlockWHT/D.GRN.B.C.M..P/2.
Power TrunkBLK/WHT.A.S..P.
Left Front Window...
Right Front Window...
Keyless Module...
TachometerBLK/GRY...
Trigger LockKEYLESS ARM OR/BLK.B.C.M..P/3.
Trigger UnlockKEYLESS DIS D.BLU/WHT.B.C.M..P/3.
Unlock MonitorKEYLESS SEN PK/BLK.B.C.M..P/3.
Unlock Monitor (Factory Alarm)L.GRN/OR.B.C.M..P/4.
Other:HVAC1 OR/BLK
ACC1 WHT/BLK
securinu
Silver - Posts: 772
Car Wire Profile for 2001 Dodge Stratus Coupe
StarterBLK/RD.IGNITION..
Notes:
T-Harness Info
Door Lock: ..
Remote Start: .
Constant 12VWHT/RD.IGNITION..
Switched 12VGRN.IGNITION..
Dome LightGRN/YL.L.K..N.
Parking LightsGRN/YL.A.S..P.
Horn...
Door LockVT.L.K..N.
Door UnlockL.GRN/RD.L.K..N.
Power Trunk...
Keyless Module...
Tachometer...
Trigger Lock...
Trigger Unlock...
Unlock Monitor...
Unlock Monitor (Factory Alarm)OR.L.K..N.
Other:HVAC1 BLU/RD
