Starter Killer
arneljr
Posted: September 08, 2005 at 12:06 AM / IP Logged
i have 98 Cav Z24. i just bought an alarm system and would like to know where to connect the starter killer? thanks
gcorrea
Silver - Posts: 436
Posted: September 08, 2005 at 12:12 AM / IP Logged
yellow wire at the ignition switch.
gcorrea
arneljr
Posted: September 08, 2005 at 10:22 PM / IP Logged
thanks for the reply but in the manual it says that i have to connect it to the distributor power supply. where do i connect it in a '98 Cav 2.4L? is it the YELLOW wire in the IGNITION SWITCH like you said? thanks
arneljr
Posted: September 08, 2005 at 10:43 PM / IP Logged
or do i have to connect it on one of the wire in the  "Ignition Control Module"
gcorrea
Silver - Posts: 436
Posted: September 08, 2005 at 11:12 PM / IP Logged
yellow wire at ignition switch, cut it and connect it to the relay.
86 to ignition 12volt
87a to yellow starter wire ignition side
30 to yellow starter wire starter side
85 to alarm output
87 no connection
diode across from 86 to 85 cathode(stripe) side to 86
gcorrea
