car security
Welcome Guest :)
chicopeechevy
Member -
Posted: December 04, 2002 at 8:42 PM / IP Logged
i am looking for the wiring locations for installing a remote starter and alarm in my 1988 mazda 929
securinu
Silver -
Posted: December 04, 2002 at 9:44 PM / IP Logged
Car Wire Profile for 1988 Mazda 929
| | Wire Color | Location | Instructions | |
| Starter | BLACK / YELLOW. | Ignition Harness. | . | | T-Harness Info | | Starter Disable/Power: | . | | Door Lock: | .. | | Complete Alarm Harness: | . | | Remote Start: | . | | Factory Keyless Upgrade: | . |
| Technical Bulletins Related to this vehicle: | | | . |
| Constant 12V | Black. | Ignition Harness. | . |
| Switched 12V | BLACK/ White. | Ignition Harness. | . |
| Dome Light | Blue/Red. | Drivers Pin Switch. | (-) System. |
| Parking Lights | RED / White. | Headlight Switch. | (+) System. |
| Horn | GREEN/ Orange. | Along Steering Column. | (-) System. |
| Door Lock | . | . | . |
| Door Unlock | . | . | . |
| Power Trunk | . | . | . |
| Left Front Window | . | . | . |
| Right Front Window | . | . | . |
| Keyless Module | . | . | . |
| Tachometer | . | . | . |
| Trigger Lock | . | . | . |
| Trigger Unlock | . | . | . |
| Unlock Monitor | . | . | . |
| Unlock Monitor (Factory Alarm) | . | . | . |
| Other: | |
10nesne1
Silver -
Posted: December 05, 2002 at 12:34 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | BLACK/ BLUE | IGNITION SWITCH HARNESS |
Ignition #1: | | | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Ignition #2: | | | BLACK/ RED | IGNITION SWITCH HARNESS |
Ignition #3: | | | N/A | |
Accessory: | | | BLUE | IGNITION SWITCH HARNESS |
Brake Light: | | | WHITE/ GREEN (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | YELLOW/BLUE | AT COIL OT AT TEST CONNECTOR |
Parking Lights: | | | WHITE/ GREEN | (+) AT LIGHT SWITCH OR AT FUSE BOX |
Headlights: | | | RED / BLACK (LO) OR | RED / WHITE (HI) (+) AT LIGHT SWITCH |
OEM Alarm Disarm: | | | RED (DOOR) LT GRN/BLK | (TRUNK) (-) DRIVER KICK PANEL |
OEM Alarm Arm: | | | N/A | |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | BLACK | IGNITION SWITCH HARNESS |
Starter Kill: | | | BLACK/ BLUE | IGNITION SWITCH HARNESS |
Ignition +12 Volts: | | | BLACK/ WHITE | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | BLUE/WHITE | (-) AT FUSE BOX OR AT COURTESY LIGHT |
OEM Horn: | | | BLUE/ORANGE | (-) STEERING COLUMN HARNESS |
Power Lock: | | | GRAY/BLACK | AT RELAYS RIGHT OF STEERING COLUMN * |
Power Unlock: | | | BLUE/RED (DLS "A") | AT RELAYS RIGHT OF STEERING COLUMN * |
Trunk Release: | | | GREEN/ YELLOW | (+) AT RELEASE SWITCH |
Alarm Input Wire: | | | BLUE/WHITE | (-) AT FUSE BOX OR AT COURTESY LIGHT |
Notes: | | * See Note #201 - Negative Pulse Door Lock Diagram. |
Monday, January 19, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
