2004 Dodge Dakota, code alarm ca-120
ncdogman
Member - Posts: 7
Posted: September 16, 2005 at 3:49 PM / IP Logged
I have a 2004 Dodge Dakota single cab truck. Can someone please give me the color codes for all the wiring in my truck. Im getting ready to hook up an alarm, so i thought it would be easier to know the wiring so i wont have to test each one. Thanks so much!
thepencil
Gold - Posts: 1,526
Posted: September 16, 2005 at 4:05 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - DODGE / DAKOTA PICKUP / 2004 / Security
12volts pnk/blk (50A), RED / lt blu(40A) +   ignition harness
Starter yellow (16 AWG)   +   ignition harness
Ignition dk. blue (16 AWG)   +   ignition harness
Power Lock WHITE/ dk. green   -   CTM, 16 pin plug, pin 10
Notes: Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays.
The CTM (Central Timer Module) is in the driver kick panel.
Can also use Directed 457C or 456L interface modules.
Power Unlock same as power lock wire
Lock Motor ORANGE / black   5wi CTM, 16 pin plug, pin 4
Notes: The CTM (Central Timer Module) is in the driver kick panel.
Unlock Motor dk. blue   5wi CTM, 16 pin plug, pin 6
Disarm Defeat pink/black   5wi CTM, 16 pin plug, pin 5
Parking Lights+ BLACK / YELLOW   +   headlight switch
Parking Lights- RED / yellow   -   CTM, 26 pin plug, pin 4
Hazards pink   -   combination flasher, pin B1
Notes: The combination flasher is behind the fuse box at the end of the driver side dash.
Turn Signal(L) lt. green (F), dk. grn/red (R) +   combination flasher, pins A3, A2
Turn Signal(R) tan (F), BROWN / red (R)   +   combination flasher, pins B3, B4
Door Trigger tan (D), tan/red (P)   -   CTM, 16 pin plug, pins 15, 13
Notes: Use both wires and diode isolate each. Also have to diode isolate from the CTM to avoid falsing. Refer to DirectFax document 1076 for wiring information.
Dome Supervision yellow   -   CTM, 16 pin plug, pin 1
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm lt. GREEN/ orange   -   CTM, 16 pin plug, pin 14
Notes: Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays.
Factory Alarm Disarm same as factory alarm arm wire
Disarm No Unlock see factory alarm disarm
Tachometer NOT dk. GREEN/ orange   ac   any ignition coil or fuel injector
Horn Trigger BLACK/ red   -   CTM, 26 pin plug, pin 5
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Sentry Key
Part #: 555CW
Alternate Part1 #: 556UW
Alternate Part2 #: 555U
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Only vehicles with gray keys have the immobilizer.
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 457CW
Alternate Part1 #: 456LW
Notes:
Be careful whose advice you buy, but be patient with those who supply it.2004 Dodge Dakota, code alarm ca-120 -- posted image.
iskidoo
Silver - Posts: 1,046
Posted: September 16, 2005 at 4:53 PM / IP Logged
Use the wiring diagram to help locate the wires but PLEASE do test each wire for the proper function before hooking to it. There are alot of wires that use similar colors and the diagram colors can always have a few variations from the vehicle.
Steve G
ncdogman
Member - Posts: 7
Posted: September 19, 2005 at 12:19 PM / IP Logged
I have a 2004 Dodge Dakota single cab truck. Can someone please give me the color codes for all the wiring in my truck. Im getting ready to hook up an alarm, so i thought it would be easier to know the wiring so testing an hook up can be much faster. Thanks so much!
dmielken
Copper - Posts: 63
Posted: September 19, 2005 at 1:23 PM / IP Logged
Make sure to test all these wires properly, don't take any of this info as a given.
12 VOLTS       pnk/blk (50a), RED / lt blu(40a)      +       ignition harness
STARTER 1       yellow (16 awg)      +       ignition harness
STARTER 2
IGNITION 1       dk. blue (16 awg)      +       ignition harness
IGNITION 2       dk. GREEN/ red (18 awg)      +       ignition harness
IGNITION 3       RED / white      +       ignition harness
ACCESSORY 1       BLACK/ orange      +       ignition harness
ACCESSORY 2       green      +       ignition harness
KEYSENSE       lt. blue      -       ign harn or ctm, 26 pin plug, pin 19
POWER LOCK       WHITE/ dk. green       -       WHITE/ dk. green
     Lock is negative trigger thru an 820 ohm resistor. Unlock is negative trigger thru a 330 ohm resistor. MUST use relays. The CTM (Central Timer Module) is in the driver kick panel.
POWER UNLOCK       same wire as power lock            n/a
DOORLOCK MOTOR       ORANGE / black       5wi       ctm, 16 pin plug, pin 4
DOOR UNLOCK MOTOR       dk. blue       5wi       ctm, 16 pin plug, pin 6
DISARM NO UNLOCK       see factory alarm disarm            n/a
FACTORY ALARM ARM       lt. GREEN/ orange       -       ctm, 16 pin plug, pin 14
     Arm is negative trigger thru a 644 ohm resistor. Disarm is negative trigger thru a 1565 ohm resistor. MUST use relays. The CTM (Central Timer Module) is in the driver kick panel.
FACTORY ALARM DISARM       same wire as alarm arm            n/a
DISARM DEFEAT
PARKLIGHTS POSITIVE       BLACK / YELLOW      +       headlight switch
PARKLIGHTS NEGATIVE       RED / yellow      -       ctm, 26 pin plug, pin 4
HEADLIGHT       purple (l), PURPLE / red (r)      +       ctm, 12 pin plug, pins 4, 5
HAZARD       pink      -       combination flasher, pin b1
TURN LEFT       lt. green (f), dk. grn/red (r)       +       combination flasher, pins a3, a2
TURN RIGHT       tan (f), BROWN / red (r)       +       combination flasher, pins b3, b4
REVERSE       PURPLE / black or BLACK/ purple      +       pwr dist ctr behind driver headlight
BRAKE       WHITE/ tan      +       brake pedal switch
PARKBRAKE       WHITE/ black       -       ctm, 16 pin plug, pin 8
DOOR PIN       tan (d), tan/red (p)       -       ctm, 16 pin plug, pins 15, 13
     Use both wires and diode isolate each. Also have to diode isolate from the CTM to avoid falsing. Refer to DirectFax document 1076 for wiring information. The CTM (Central Timer Module) is in the driver kick panel.
HOOD PIN
TRUNK PIN
DOMELIGHT SUPERVISION       yellow      -       ctm, 16 pin plug, pin 1
TACH       not dk. GREEN/ orange       ac       any ignition coil or fuel injector
     On the 2.5L/3.9L/5.9L models use BLACK/ gray at the ignition coil. The 4.7L models have an ignition coil for each cylinder, use the wire that is NOT GREEN/ orange at one of the coils.
ncdogman
Member - Posts: 7
Posted: September 21, 2005 at 9:32 PM / IP Logged
hi everyone. ive just installed a code alarm ca-120 alarm in my 2004 dodge dakota. i have a big problem. first is the truck had no factory alarm installed. the only thing that i hooked up was the door pin switch and the parking lights. the problem is if i hook the siren up it will scream and not stop. it doesnt matter if i disarm the alarm or not. however i noticed that if the siren isnt hooked up i can disarm the alarm and arm it just fine. i know this because when i arm it and disarm it with the siren not hooked up, i can see the parking lights flash to tell me. but also, heres another thing, i took the fuses out of the main power lines and the led still flashes. i also noticed that there is a clicking sound, almost like an on bourd relay click for around 8 sec. and then it stops with the fuses taken out of the system.  the truck does not have power locks nor windows. and i felt as if i hooked everything up right because the lights will flash, the alarm turns off when i start the truck. it will arm and disarm without the siren hooked up, but once the siren is hooked up, you cant shut it off. also, the instuctions say that the remotes has been factory programed, so i tried reprograming the remotes and that still hasnt worked. please help! jeff
lilchepe
Member - Posts: 43
Posted: September 21, 2005 at 9:59 PM / IP Logged
Try cheking your power, & ignition wires.  Its posible that you grabbed the wong power and ignition.  Test the wires for voltage.
ncdogman
Member - Posts: 7
Posted: September 21, 2005 at 10:10 PM / IP Logged
hi there. i know that i have the right ignition wires because it reads a constant 12 volts from ignition to on to crank and to the motor running.
Sunday, March 1, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
