Remote start 1998 Grand am
hyperlite137
Member - Posts: 17
Posted: September 29, 2005 at 10:49 PM / IP Logged
I installed a remote alarm starter combo in my 98 Pontiac Grand am, I used a DEI 555L Passlock module and for some reason the car still will not start.  Any ideas why this is happening ?
cntrylvr79
Silver - Posts: 582
Posted: September 29, 2005 at 10:52 PM / IP Logged
Does it not crank at all or does it crank start then immediately die?  If it doesn't even crank you might want to check your connections on the remote start especially the shutdown triggers.  If it cranks then dies then you've got something screwy with the 555l.
Cause I'm So white and nerdy...
First Class Certi-fried installer
hyperlite137
Member - Posts: 17
Posted: September 29, 2005 at 11:33 PM / IP Logged
It cranks but does not start up.
mo12v
Posted: September 30, 2005 at 8:15 AM / IP Logged
R U sure you have it connected to "Bulb Check " wire?
Did you "Learn" resistance?
Is it Powered up when Cranking?
MO
