passlock II flashing security light
MikeHusain
Copper - Posts: 139
Posted: October 02, 2005 at 10:38 PM / IP Logged
I just installed a autopage 855 in a 2005 envoy.  everything works fine except i noticed that when I arm the car, the security light flashes about 20 times and then goes out.  Even though it goes out, It still worries me.  I use the 555L and the 555G modules for the passlock  bypass and the door lock interface.  Also I was wondering if anyone knows how to access the dome light wire and parking light wire.  Diagrams say under rear seat at fuse box, but hard as hell to access, brown-park light, and grey/black for dome. the Grey/black goes to the door lock module as a plus voltage and converts it to a negative output from another wire which goes the alarm brain.  I dont have the grey/black(domelight) and brown(park light) wires hooked up yet.  I am not sure if these wires especially the dome light might have anything to do with the security light flashing when i arm the car.                 Thanks......
redpeppers
Silver - Posts: 483
Posted: October 02, 2005 at 10:46 PM / IP Logged
it sounds like.....because the wires r not hooked up yet......the factory security is cause the light 2 stay on.....hook those 2 wires up and it will prolly fix the problem......also u may not need the parking light wire....the 555g will prolly do the light for u through the factory settings
Where theres is a wire there's a way.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
