remote start, 2001 honda accord
wgasca
Member - Posts: 29
Posted: October 03, 2005 at 12:35 AM / IP Logged
I Have a cammando car alrm and everything works accept for the remote start. The remote start goes on but the engine wont crank over .
can anyone help
Platinum - Posts: 12,488
Posted: October 03, 2005 at 8:01 AM / IP Logged
Make, model & year of car please.
Hickmanae3
Copper - Posts: 67
Posted: October 03, 2005 at 9:15 AM / IP Logged
i have a 97 explorer and mines do te same but it starts up if i have had the engnie on  for a while and then try the remote start . but to wait 5 ours and try try it doesnt work.
No security system can beat the tow truck :(
KarTuneMan
Platinum - Posts: 7,056
wgasca
Member - Posts: 29
Posted: October 04, 2005 at 8:09 PM / IP Logged
I have a 2001 honda accord lx sedan and a cammando 2 way paging alrm system. everytime i try to remote start the car it will crank but it wont turn over. i have the bypass module installed. it actually worked for a few months but now it just wont turn over. can anyone help me.
thank you
mo12v
Posted: October 04, 2005 at 8:19 PM / IP Logged
Crank & Turn Over???
If it only CRANKS & Does NOT Start (Run).....
Have you tried Remote Starting it with your Ignition Key in the Ignition?
Are you sure ALL the wires are Powering up?
Including the Immobilizer.
MO
redpeppers
Silver - Posts: 483
Posted: October 04, 2005 at 11:39 PM / IP Logged
what bypass did u use?  try this put the key in the ignition then try to remote start and see if it starts....if it does.....then u have a bypass problem
Where theres is a wire there's a way.
wgasca
Member - Posts: 29
Posted: October 08, 2005 at 1:56 AM / IP Logged
I have a 2001 honda accord lx sedan and a cammando 2 way paging alrm system. everytime i try to remote start the car it will crank but it wont turn over. i have the bypass module installed. The bypass mod is the one that soent require a spare key. I also tried to us the r/s with the key in the ignition but it still does the same thing. it actually worked for a few months but now it just wont turn over. can anyone help me.
jaurora
Silver - Posts: 429
Posted: October 14, 2005 at 4:04 PM / IP Logged
It may be the ring around the ign cylinder. I had a ford where if it wasent placed just right it would not start.
MECP certified (If it really means anything)
Jeremy
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
