power window unit
vw@ner
Posted: October 05, 2005 at 6:32 PM / IP Logged
hello !
I installed an alarm....and i wonder....maybe i can make a window role up module by myself....
(for two windows) 2 relays ,2 diodes,2 capasitors (for the relay).....
will it work......? and if some one has an exact ...diagram of the system i would be very glad :)
thank you !
orangesuburban
Member - Posts: 47
Posted: October 05, 2005 at 7:09 PM / IP Logged
i think you looking for DEI part number 530T, google it.... it should fit your needs.
mo12v
Posted: October 05, 2005 at 7:18 PM / IP Logged
Sure you could spend a couple of bucks for Relays & parts , wire them up & Install them with your own wiring??!!!
Or spend a couple of bucks & buy one pre wired & made just for that. Without all the headache & fuss, so the next guy knows what the wires do ...
OMEGA also makes one......
MO
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
