RS-855LCD installation, 96 Land Cruiser
fzj80
Posted: October 14, 2005 at 1:09 AM / IP Logged
Hello. I am here for the first time.
I just finished installing RS-855LCD into my 96 Toyota Land Cruiser. Everthing seems to work except for the remote starter. I tried to program with TACH, but the brain doesn't seem to learn. I also tried to reprogram it to default. But when I pressed * button, the remote just beeped three times and nothing happened. Does anybody have any idea?
I also noticed that programming process doesn't work sometimes. I had to disconnect and connect wires and repeat reprogramming process several times and then worked.
Thanks.
mrcllusb
Copper - Posts: 489
Posted: October 14, 2005 at 3:27 AM / IP Logged
If you have to keep disconnecting wires and stuff sounds like you have a bad brain..
"ole blake"
