crimestopper
dmcollazo
Posted: October 14, 2005 at 5:30 PM / IP Logged
Hi! Had my battery disconnected to do some work. Put cables back on and car sounded like the battery was low(sluggish) It started but really rough. Changed old battery. Now I can't get even a click from the starter. You can hear a tick noise from around the crimestopper module in the dash. It has a kill switch in it. I also activated the alarm---No Blinking Parking Lights! I also unlocked the drivers door manually and opened it and No Horn (alarm sound) also opened the hood, and again nothing. Could the alarm be on the fritz and messing with my starter, cause I can get the engine to crank if I hot-start it straight from the battery to the starter. Any help can be useful. Thanks!
d collazo
78musicman
Copper - Posts: 78
Posted: October 14, 2005 at 6:01 PM / IP Logged
new battery is dead.
colorado tap the rockies
dmcollazo
Posted: October 14, 2005 at 6:23 PM / IP Logged
no actually the battery is not dead because I am able to hot start the enging straight from the battery to the starter. I keep hearing a click in the dash board under the steering wheel. I also the the same click if I hit the door lock button up when the locks are already unlocked.
d collazo
mrcllusb
Copper - Posts: 489
Posted: October 14, 2005 at 7:09 PM / IP Logged
The click sound you hear is the relay..
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: October 14, 2005 at 7:10 PM / IP Logged
Check all of your fuses.Alarm and car
"ole blake"
dmcollazo
Posted: October 14, 2005 at 9:37 PM / IP Logged
Thank you all for your replies! which relay should I check? Already checked the starter relay in the fuse box. Actually put a new one in.No change though. It's a 96 T&C 3.8. It has the crimestopper rs900iv. But it also has a factory alarm with the kill switch. There are a bunch of relays under the dash by the E-Brake also. Will try the battery thing also. Thanks again!
d collazo
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
