Viper 350HC into a 00 Jeep Wrangler
cannibal
Posted: October 15, 2005 at 6:49 AM / IP Logged
I am new, so bare with me, and this will be my first alarm install.
I have done several searches, and believe I have got the answers, but would be appreciated if someone can dbl check my wiring :)
Viper                    Jeep
Orange                   Starter Kill Relay
White                    BLACK / YELLOW
WHITE/ Blue               N/A for me
Black White              Dome light Supervision Relay???
Green                    Yellow (at headlight switch)
Blue                     Hood Switch
Black                    Chassis Ground
Yellow                   Dark Blue (At ignition)
Brown                    To Siren
Red                      Pink/Black (At ignition)
I think the above is correct, what is a dome light supervision relay, tha install manual says optional, but what does it do?
Secondly, from what I can gather, if I install the starter kill relay, do I cut the Dark Blue ignition wire and join it with the green and black starter kill relay wires, and leave the Yellow (viper,switched ignition input)wire disconnected?
Therefore if I chose not to install the starter kill relay, just splice the yellow (viper,switched ignition input)into the Jeep dark blue igniton wire?
Any feedback would be appreciated.
cannibal
Posted: October 15, 2005 at 6:54 AM / IP Logged
A few spelling mistakes above, should be a 350HV alarm.
78musicman
Copper - Posts: 78
Posted: October 15, 2005 at 7:01 AM / IP Logged
The dome light supervison reley?You use either the positive or negitive (Jumper) from alarm.Hooks into the under dash light.You have to test to see if it gets positive or negitive to light it up,one wire will be a constant the other is needed to turn it on.No sure on other ??If its a softtop i would get a radar prox sensor (ebay $30)and battery back up siren.
colorado tap the rockies
cannibal
Posted: October 15, 2005 at 7:13 AM / IP Logged
Have got a radar sensor, and batt back up from Ebay already.
The Dome light supervision relay was something mentioned in the Viper instll PDF, when i pulled out the old alarm, the existing wire was spliced to the light under the dash, so I'll just do the same.
Main concern was the wiring for the starter kill relay installed vs not installed. I am tending towards not bothering, as car jacking isn't really an issue over here in Australia, but if its simple to do will do it as well.
cannibal
Posted: October 15, 2005 at 6:13 PM / IP Logged
Ok searched some more.
Anyone able to confirm this is right.
Viper                      Jeep
Green wire off relay       Ignition end of DK Blue Wire
Black wire off relay       Starter end of Dk Blue Wire
So which wire do I connect the yellow one of the Viper Brain, says to (+)switched ignition input, but from what i can gather that is the Dk Blue wire the starter kill attaches to?
mrcllusb
Copper - Posts: 489
Posted: October 16, 2005 at 12:29 AM / IP Logged
Find the wire coming from us ignition side,not the starter side that shows 12v when the key is in the run position,and when the vehicle is cranking.Once the vehicle is running,the voltage should drop off.Remember only when the key is in the run position,and when you are cranking the vehicle.
"ole blake"
