2005 Mitsubishi Lancer
forbidden
Platinum - Posts: 5,354
Posted: October 15, 2005 at 9:05 PM / IP Logged
Who has the wire info for rs / alarm.
extreme1
Silver - Posts: 1,070
Posted: October 15, 2005 at 9:10 PM / IP Logged
OOOO OOOO PICK ME
Shaughn Murley
Visions Electronics
Red Deer, Alberta
swamprat323
Gold - Posts: 1,335
Posted: October 15, 2005 at 9:11 PM / IP Logged
2005 MITSUBISHI LANCER 4DR SEDAN EVO VIII
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          WHITE          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          WHITE          (-)          FUSEBOX , WHITE PLUG AT BOTTOM
     Domelight Super          USE DOOR TRIGGER
     Trunk Trigger          GREEN/ ORANGE          (-)          TRUNK LIGHT
     Alarm Disarm          GRAY
     Parking Lights          GREEN/ YELLOW (L) GREEN / WHITE (R)          (+)          FUSEBOX , WHITE PLUG AT BOTTOM
     Convenience
     Headlights-Lo          RED / YELLOW (L) PINK (R)          (+)          RELAY CENTER UNDER HOOD
     All Hazrd Lights          WHITE          (-)          HAZARD SWITCH
     Wipers-Lo          BLUE/RED          (+)          WIPER MOTOR
     Wipers-Hi          ORANGE          (+)          WIPER MOTOR
     Parking Brake          BLUE/RED          (-)          PARKING BRAKE SWITCH
     Remote Start
     Accessory 1          BLUE/BLACK          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BLUE/WHITE          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          SOME MODELS HAVE RF TYPE IMMOBILIZER SYSTEMS
     Key Sense          BLUE
               RESTS AT GROUND OPEN WHEN KEY IS IN, USE RELAY TO OPEN.
     Tachometer          BLACK / YELLOW          (-)          IGNITION COIL
     Speed Sense          BLACK/ RED          (AC)          DIAGNOSTIC CONNECTOR UNDER DRIVER DASH
     Brake Lights          GREEN          (+)          BRAKE SWITCH
     Reverse Lights          BROWN          (+)          DRIVER KICK PANEL, HARNESS TO REAR
     Horn          BLUE/RED OR RED          (-)          HORN SWITCH
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          LT.GREEN          (-)          DRIVER KICK DOOR HARNESS
     PowerLock          VIOLET          (-)          DRIVER KICK DOOR HARNESS
     Driver Mtr Unlock          WHITE          (REV)          DRIVER KICK DOOR HARNESS
     Driver Mtr Lock          BLUE/RED          (AC)          DRIVER KICK DOOR HARNESS
     LF Window Up          RED / BLACK          (REV)          DRIVER WINDOW SWITCH IN DOOR
     LF Window Dn          GREEN/ BLACK          (REV)          DRIVER WINDOW SWITCH IN DOOR
     RF Window Up          BLUE/WHITE          (REV)          DRIVER KICK DOOR HARNESS
     RF Window Dn          BLACK/ WHITE          (REV)          DRIVER KICK DOOR HARNESS
     LR Window Up          WHITE          (REV)          DRIVER KICK DOOR HARNESS
     LR Window Dn          BLUE          (REV)          DRIVER KICK DOOR HARNESS
     RR Window Up          BLUE/BLACK          (REV)          DRIVER KICK DOOR HARNESS
     RR Window Dn          GREEN/ YELLOW          (REV)          DRIVER KICK DOOR HARNESS
