parking light 99 blazer
Moosetooth
Member - Posts: 10
Posted: October 26, 2005 at 7:53 PM / IP Logged
Can anyone tell me how to get the parking lights to work on my remote starter? Boa 265b w/ 556L bypass The wire suggested by my online support says white wire in lt blue plug at BCM. Supposed to get a negative voltage only after turning on the parking light switch but my probing shows constant negative voltage.  I tried using this wire but lights don't flash when I try to remote start.
Also, would not being wired to the parking lights keep the remote starter from working?
mo12v
Posted: October 26, 2005 at 8:04 PM / IP Logged
Cal me OLD DOG............But I always wire to Switch:
Parking LampL BLUE (+)AT HEADLIGHT SWITCH
MO
Moosetooth
Member - Posts: 10
Posted: October 26, 2005 at 10:17 PM / IP Logged
I just tried it. Switched the wires, relearned the bypass in case it makes a difference, disconnected and reconnected the car battery and "relearned" the transmitter.  Same as before, cranks but no start and no parking light flash. . Runs fine starting with the key.
Moosetooth
Member - Posts: 10
Posted: October 31, 2005 at 7:49 AM / IP Logged
Does the crank but no start mean the bypass isn't working?The security light comes on when I try to remote start. Chevy fuel pump is very audible but I think the passlock is turning it off during the cranking.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 31, 2005 at 11:49 AM / IP Logged
Parking lights: there are 2 white wires in that plug, you got the write one?
Also, would not being wired to the parking lights keep the remote starter from working?  No
You have a passlock issue
Moosetooth
Member - Posts: 10
Posted: October 31, 2005 at 8:44 PM / IP Logged
Thanks.
