LEDs...
Big Purds
Silver - Posts: 574
Posted: December 11, 2002 at 5:13 AM / IP Logged
will my Viper 500 ESP LED lead out of the brain carry enough power to trigger a relay so I can run multiple LEDs?
if not, what must I do to run multiple LEDs? I still want them to trigger with the alarm and flash with the alarm and such...
thanx,
Big Purds
sufferrar
Copper - Posts: 190
Posted: December 11, 2002 at 6:38 AM / IP Logged
The led voltage is usually 2V . this may not be enough unless you can find a 2 volt relay . You can try a transistor type switch which can then drive a relay . you can also run multiple leds with the same led output but will light dimmer according to the amount you put.
I had tried it once in parallel but only one led worked . in series  two worked but dim .
Any one else has any suggestion?
"I'm So Loud It Hertz"
dcash18
Member - Posts: 38
Posted: December 11, 2002 at 8:07 AM / IP Logged
You can wire up to 4 I think off of the same output from the brain without a relay
donsmith249
Member - Posts: 19
Posted: December 11, 2002 at 10:08 AM / IP Logged
DEI also makes a part to run multiple led's on one output, you can then put them in diffrent patterns such as scanning.
Don Smith
Plano TX
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
