Vats/Passlock/Passkey
dereck
Member - Posts: 28
Posted: December 11, 2002 at 12:49 PM / IP Logged
I was wondering if anyone knows what security system a 2002 Chevy Tacker has? VATS?
PASSLOCK1?2?
I need to know this for installing a remote starter.
Also if anyone knows the wire to hock up the parkbrake wire to. Thanks
miner1no
Member - Posts: 9
Posted: December 11, 2002 at 2:11 PM / IP Logged
Call the dealer and give them your VIN....if there in a good mood they'll check the GM database and pull down the options...Bring the guys in service some donuts or somthing...before you ask.
Miner
jrilla
Gold - Posts: 1,498
Posted: December 11, 2002 at 2:55 PM / IP Logged
As far as my databases show that vehicle dooes not have an anti-theft device.
J Rilla
Owner/Installer
securinu
Silver - Posts: 772
Posted: December 11, 2002 at 5:32 PM / IP Logged
i just did one and no security whatsoever. it is a suzuki  so no factory system
djfearny2
Silver - Posts: 810
Posted: December 11, 2002 at 7:16 PM / IP Logged
iut should have passlock 11 this system is twi wires an r-code wire and a ground reference wire. this will need to be interfased with a part such as the dei 555l in order to remote start. the wires in colum are thin wires colored either yellow and black or in most trucks it is yellow and ORANGE / black. the yellow in both cases is the r-code wire and the other wire in both cases is the ground reference. in a 2 002 i belive it is yellow and ORANGE / black.
Jon
Installer/Help Technician
---coral springs florida---
djfearny2
Silver - Posts: 810
Posted: December 11, 2002 at 7:19 PM / IP Logged
although my dei charts say that there is no bypass system in that car so you good to go although you have to give power to second igniton during before remote start or the transmission will not work right even after you take the car over with the key,.
Jon
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
