Code Alarm Remote start only?
Stu
Member - Posts: 12
Posted: November 01, 2005 at 6:13 AM / IP Logged
Hi, i have a code alarm model ca-545 and would like to know if i can just hook it up as a remote start
without the alarm feature? I really don't need the alarm part and it would make it alot easier to install.
        Thanks........Stu C.
pss5075104
Copper - Posts: 144
Posted: November 01, 2005 at 10:31 AM / IP Logged
you should be able to. just hook up the ing harness, brake wire, tach wire, power, ground, parking lights if u want them, door locks if you want them, hood pin if you want. and that should be about it.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
Stu
Member - Posts: 12
Posted: November 01, 2005 at 8:52 PM / IP Logged
Thanks for the info,i will set it up as just the remote start and give it a try.
tragik
Copper - Posts: 169
Posted: November 01, 2005 at 9:08 PM / IP Logged
If that alarm monitors the ignition, then its possible that    you could still set off the alarm if it is armed and you start it with the key. Even if you dont hook up the siren, the lights will still flash until you hit unlock. Try hooking it up and then puting it into valet mode and see if the starter portion sill works. If so, just leave it in Valet forever. If not, then you are just going to have to remember to unlock it if you go to start it and your lights flash.
Northstart.....or start it your damn self.
Chris Luongo
Platinum - Posts: 3,746
Posted: November 01, 2005 at 10:47 PM / IP Logged
I have a CA-545 in one of my personal cars, and I do like it.
A couple of tips:
1. You may or may not already know this, but the CA-545 is of no use unless you have the CA-425 Master Module to go along with it.
The CA-545 is just wiring, remotes, antenna, siren, and so forth-----the 425 is the main brain, along with some other wiring.
2. On those Code Alarms, to enter programming, the first step is that you must open a door. Therefore, you'll have to either hook up the door trigger correctly, or use a jumper wire to ground the door trigger input as you go into programming.
Stu
Member - Posts: 12
Posted: November 02, 2005 at 5:46 AM / IP Logged
A couple of tips:
Yes i have the 425 master module and i have it partially installed,all the wires on the 6 pin starter harness and working on whatever else is needed on the 22 pin harness,tach,doors,lights etc. Would also like to hook up the wires for the rear window defroster.                                                         Thanks.......Stu.
Stu
Member - Posts: 12
Posted: November 02, 2005 at 5:52 AM / IP Logged
I forgot to mention it is being installed on a 2005 Kia Spectra.
davidmmm
Posted: December 13, 2005 at 8:58 PM / IP Logged
any news
kohara73
Copper - Posts: 192
Posted: December 18, 2005 at 10:19 AM / IP Logged
You'll also have to keep in mind that the 425 has a built in shock sensor, and yes, it does monitor the ignition, so you must unlock(disarm) it or the alarm will go off and your car wont start.
Keith
