01 dodge caravan
bak0707
Member - Posts: 38
Posted: November 01, 2005 at 10:42 AM / IP Logged
I need a little help with this install. I will be installing a r/s k/e on this van this week and im not sure on a couple of things. first all the wiring diagrams ive looked at have been diffrent. so if anyone has a recent diagram that would help a lot. also ive heard that i will need relays and resistors to install the unit prperly. ive installed relays before but never had to use resistors so if thats true i may need another diagram. one other thing is the power wire  there saying has to come from the battery. ive always got mine from the colum.
thanks any help would be app.
deviousjoker
Copper - Posts: 102
Posted: November 01, 2005 at 11:57 AM / IP Logged
If you don't have experience with relays and resistors, I wouldn't suggest this be your first car to try.  You'll need atleast an addtional 4 relays and atleat 4 different ohm resistors.  Take it and have it proffesional installed
First Class MECP Installer
Platinum - Posts: 12,488
Posted: November 01, 2005 at 12:23 PM / IP Logged
For the bypass & door lock system I would use CHDL1A-PK which does Lock/Unlock, OEM security arm/disarm, Panic, Starter enable & Transponder bypass: RF override through induction using loop antenna (Transponder included no key required.
This will make installation a whole lot easier and no need for relays or resistors. It will self program all the necessary values when programmed properly.
