Wiring Specs?
diabloed
Copper - Posts: 133
Posted: December 11, 2002 at 7:29 PM / IP Logged
I was wondering if anyone had a wiring diagram for a 2003 Subaru Forester? Preferably something that includes wires for window roll-up.
Thanks In Advance
10nesne1
Silver - Posts: 284
Posted: December 11, 2002 at 7:36 PM / IP Logged
YEAR: 2002  MAKE: Subaru  MODEL: Forester  STYLE:
|       ITEM          |     WIRE COLOR      |POL |       WIRE LOCATION        |
|                 12V                                  |white                | +  |ignition harness            |
|             STARTER                             | WHITE/ black          | +  |ignition harness            |
|            IGNITION                                |green                | +  |ignition harness            |
|           ACCESSORY                       |yellow               | +  |ignition harness            |
|          POWER LOCK                   |RED / white            | -  |keyless module *1           |
|        POWER UNLOCK                    |yellow/red           | -  |keyless module *1           |
|          LOCK MOTOR                          |lt. GREEN/ black      |    |keyless module *1           |
|        UNLOCK MOTOR                      |blue/white           |    |keyless module *1           |
|       DISARM DEFEAT                         |RED / green            |    |keyless module *1           |
|    PARKING LIGHTS +                         |orange               |    |parking light switch        |
|    PARKING LIGHTS -                          |BLACK/ white *2       |    |headlight switch            |
|          HEADLIGHTS                                |green or grn/wht *2  | -  |headlight switch            |
|        DOOR TRIGGER                           |yellow               | -  |keyless module *1           |
|    DOME SUPERVISION                        |use door trigger     |    |                            |
|     TRUNK/HATCH PIN                           |tied in with doors   |    |                            |
|   FACTORY ALARM ARM                          |factory remote only  |    |                            |
|FACTORY ALARM DISARM                        |factory remote only  |    |                            |
|          TACHOMETER                             |blue or RED / grn      |    |ignition coil               |
|         SPEED SENSE                           |GREEN/ black          |    |cruise control mod in DKP   |
|          BRAKE WIRE                             |WHITE/ black          | +  |brake pedal switch          |
|        HORN TRIGGER                        |          RED / green            | -  |steering column or keyless  |
|              WIPERS                                           |blk/blu(L),RED / blu(H | +  |steering column             |
|   LF WINDOW UP/DOWN                         |blue - blu/red       | A  |driver window switch        |
|   RF WINDOW UP/DOWN                               |blk/blu - RED / blu    | A  |driver kick panel           |
|   LR WINDOW UP/DOWN                               |grn/yel - blu/yel    | A  |driver kick panel           |
|   RR WINDOW UP/DOWN                       |blu/wht - grn/wht    | A  |driver kick panel           |
| SUN ROOF OPEN/CLOSE                               |not recommended      |    |                            |
NOTES:
*1 The keyless module is to the left of the steering column.
*2 The negative parking lights and headlights wires only work with the
ignition on.
Sorry, don't have 2003 and hopefully this will help.  Most Subaru are easy to work on. Have fun
diabloed
Copper - Posts: 133
Posted: December 11, 2002 at 7:43 PM / IP Logged
can anyone else verify that these will work for the 2003
