Compustar
aaronU
Copper - Posts: 73
Posted: November 07, 2005 at 9:11 AM / IP Logged
I have a 2W900FM-S (only remote start). Can I add the alarm? If so what would the parts run.
If upgraded I have a question about the page feature. Right now (without an alarm) if the doors are locked with remote, then doors are opened without using remote (using a key, breaking in) the remote beeps 3 times. With the alarm, is the page any different?
I just had my vehicle broken into. I'm sure the remote beeped, it just didn't wake me up.
Platinum - Posts: 12,488
Posted: November 07, 2005 at 3:42 PM / IP Logged
You will need to purchase the CM3000 CPU to make this a two way alarm/remote starter. The remote control is the same, just the CPU has the outputs for siren, impact and other trigger's. The communication between the remote and the CPU is also different in that the icons on the remote control actually work properly instead of just being there.
Monday, January 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
