Door trigger on a 02 dodge ram?
eeh1025
Copper - Posts: 113
Posted: November 10, 2005 at 8:58 PM / IP Logged
Hey there on most other alarms i have done i always used the wire that turns the domelight on, can i do that with the dodge ram if not what do i have to do.
thanks
mo12v
Posted: November 10, 2005 at 9:07 PM / IP Logged
Are you doing this Instal...ONE Wire at a Time?? Door trigger on a 02 dodge ram? -- posted image.  Door trigger on a 02 dodge ram? -- posted image.
Dome LightBROWN (-)DRIVER A PILLAR
Dome Light: Remove Support Handle, Drivers Side Window 2 Screws,Remove Panel Behind Support.Dome Wires Are In A 12 Pin Connector Behind The Panel.
Alt Door Triggers- Dr Front=TAN,Dr Rear= VLT/ORG @ Driver Kick Pass Front= TAN/RED, Pass Rear= TAN/YEL @ Pass Kick All (-) Diode Isolate
MO
eeh1025
Copper - Posts: 113
Posted: November 10, 2005 at 9:17 PM / IP Logged
Hey there yes im doing this install my self, this truck wire is a pain in the ***, i used to no resistors and just easy wiring, but i lucky this sites is here with all you guys. Okay so what im going to do is use the brown wire and hook up my negitive door trigger from the alarm, One more thing, the dome turn on that the alarms does can i hook it to the same brown wire?
thanks again
mo12v
Posted: November 10, 2005 at 9:23 PM / IP Logged
Yes......Negative out from Alarm
MO
Chris Luongo
Platinum - Posts: 3,746
Posted: November 11, 2005 at 6:47 PM / IP Logged
The domelight wire is not too hard to get to on that car.
--On the driver's A-pillar, pop out the two rubber plugs around the grab handle, remove the 10mm bolts inside, and remove the pillar.
--Domelight wire is brown, positive trigger.
--If you manually disable the domelight, however, your alarm will not trigger.
--The domelight wire is affected by the delayed turn-off. If your alarm makes extra chirps when you "forget" a door open, the domelight wire will cause you to get those extra chirps too.
eeh1025
Copper - Posts: 113
Posted: November 11, 2005 at 6:58 PM / IP Logged
okay thanks alot for that i was having alittle trouble finding it, 1 more question you said it postive from the alarm and im told its negitive, also my alarm has a dome light ture one when you disarm the alarm can i hook that up to that same brown wire.
thanks
