98 4runner 12V Constant/Switched
quebert00
Member - Posts: 7
Posted: November 18, 2005 at 10:49 PM / IP Logged
I am trying to hardwire my radar detector and can't seem to find a 12V. Either constant or switched. The voltmeter read all the wires I checked at 24V or so and the detector doesn't turn on. Any idea where I can get a 12V from without removing any panels? Is there another fuse panel that I am missing other than the obvious one? This is in a 98 4runner. Let me know. Thanks in advance.
mo12v
Posted: November 18, 2005 at 10:53 PM / IP Logged
Should be able to get a Fuse .....
Otherwise:
AccessoryBLUE/REDIGNITION SWITCH HARNESS
MO
Mike M2
Platinum - Posts: 2,652
Posted: November 20, 2005 at 8:36 PM / IP Logged
Most Toyota ignition fuses are marked "AM1" or "AM2"....
Monday, April 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
