2005 Smart Car, remote start
perfect tones
Member - Posts: 9
Posted: November 22, 2005 at 8:52 AM / IP Logged
I have a customer with a 2005 Mercedes Smart Car, fortwo, and they would like a Remote starter done on it.   I have searched on a few progarms, and websites for any Wiring Info on this vehicle but have come up with very little.
If anyone knows Wiring Info, or a place i can find out more, Please PM or post a reply! any help would be much appretiated.
thank you,
Curtis
Pefect Tones
"Luck" is when Opportunity meets Preperation.
Autoobsession
Copper - Posts: 119
Posted: November 22, 2005 at 9:13 AM / IP Logged
Tell me an exact Model.
JWorm
Platinum - Posts: 2,208
Posted: November 22, 2005 at 9:48 AM / IP Logged
DEI has a little info....and its from a 2004 fortwo
12volts
Starter      Blue      +      loom to column
Second Starter
Ignition      Red      +      see note
Notes: This wire is marked E and is found at the rear of the fusebox
Second Ignition
Third Ignition
Accessory
Second Accessory
Keysense
Power Lock
Power Unlock
Lock Motor      grey/light blue      5wi      rear of fusebox
Unlock Motor      WHITE/ blue      5wi      rear of fusebox
Parking Lights+
Parking Lights-
Hazards
Turn Signal(L)      green      +      see note
Notes: These wires can be found in a multiway connector at the rear of the fusebox
Turn Signal(R)      pink      +      see note
Reverse Light
Door Trigger      BROWN / blue      -      black plug rear of fusebox
Dome Supervision
Trunk/Hatch Pin      same as door
perfect tones
Member - Posts: 9
Posted: November 22, 2005 at 11:13 AM / IP Logged
2005 Fortwo,Smart Car Passion model.
Thanks.
Curtis
