2503 astrostart
bigbadsam
Posted: November 23, 2005 at 12:58 PM / IP Logged
Does anybody knows how to cancel the 2 sensor that goes to the shift lever and to be able to make the remote starter module act like if it was an automatic car. Do I have to add a wire to make it think it's a automatic trany car. Thanks, Bigbadsam.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 23, 2005 at 3:11 PM / IP Logged
You cannot....this unit is for manual trans ONLY.....disconnect the sensors, and the unit will not function.
BoominRolla
Copper - Posts: 198
Posted: November 25, 2005 at 5:42 PM / IP Logged
Couldn't you get a 2106xr? add an alarm kit to it. and program dip switches 4,5,6,7 for automatic?
mobilefx
Copper - Posts: 48
Posted: November 26, 2005 at 5:19 PM / IP Logged
you have to use any astrostart unit that has a "U" after the unit. .  example  2106xr U  ...4204U
along with that you need to plug in the manual transmission module to safely do it.  cheap and easy module.  work very well and give you different options as far as activating the "reservation sequence"
chris
mobile f/x
