2005 Dodge Ram Headlights
westminsterfjr
Member - Posts: 9
Posted: November 27, 2005 at 10:32 AM / IP Logged
Folks:
What resistor value is required to activate the headlights on a 2005 Dodge Ram?
There seems to be a difference between 2004 and 2005.
Wire color = WHITE/ lt. GREEN (-) @ HEADLIGHT SWITCH
For 2004:
Parking light = use 330 Ohm to ground
Head lights   = use 700 Ohm to ground
For 2005:
Parking light = use 590 Ohm to ground
Head lights   = use ??? Ohm to ground
Thanks,
-Ken
mo12v
Posted: November 27, 2005 at 11:40 AM / IP Logged
Parking LampWHITE/ GREY (+)HARNESS LEFT OF COLUMN **
** Also Found As WHITE/ LT GREEN (-) At Headlight Switch. Must See Chassis Ground Through 250 Ohm Resistor.
HeadlightsWHITE/ LT GREENAT HEADLIGHT SWITCH *
* WHITE/ LT GREEN Must See Chassis Ground Through A 1.4K Ohm Resistor To Turn On Headlights & Parking Lights
MO
westminsterfjr
Member - Posts: 9
Posted: November 27, 2005 at 11:46 AM / IP Logged
MO:
Is that saying 1.4k ohm will turn on both the headlights AND parking lights?
Thanks,
-Ken
mo12v
Posted: November 27, 2005 at 11:49 AM / IP Logged
YEPPER...........
can be within 10%
MO
westminsterfjr
Member - Posts: 9
Posted: November 27, 2005 at 7:47 PM / IP Logged
Thanks, MO.
Would I need a relay for triggering the headlights? The output from the remote starter is 200mA(-). Also, would 1/4 watt resistors be sufficient?
Thanks,
-Ken
mo12v
Posted: November 27, 2005 at 7:55 PM / IP Logged
Sometimes............Try it first
I usually put Relays on the units I use, because most manufacturers recommend it
MO
tragik
Copper - Posts: 169
Posted: November 27, 2005 at 7:58 PM / IP Logged
you do need a relay. to make this happen without causing problems you have to seperate the wire with a relay, and isolate it from the switch.
Northstart.....or start it your damn self.
westminsterfjr
Member - Posts: 9
Posted: November 27, 2005 at 8:37 PM / IP Logged
I'm a little confused.
According to Bulldog's diagram, it says the resistor wattage rating is not important.
So that's implying that a small 1/4 watt resistor is sufficient.
I = (P/R)^(0.5)
= (0.25 watts/590 ohms)^(0.5) = 20.58 mA
This is saying that the current will not exceed 20.58 mA. If my output wire is 200mA, then why would I need a relay as the diagram specifies?
2005 Dodge Ram Light Wiring Diagram
Thanks,
-Ken
westminsterfjr
Member - Posts: 9
Posted: November 27, 2005 at 9:43 PM / IP Logged
I agree that I can't go wrong by using a relay.
My assumption is these multiplexed wires serve as low current triggers to the BCM (body control module). The BCM then takes the resistive signal and does the actual controlling of lights (in this case).
-Ken
b-roy
Copper - Posts: 56
Posted: November 27, 2005 at 10:07 PM / IP Logged
Did one of these not too far back. I tried using the output straight out for experimental purposes, didn't work right from the get go. Relayed it and was off to the races.
