1996 Dodge Caravan, factory keyless
iculokn
Posted: December 02, 2005 at 9:37 AM / IP Logged
Anyone know the location & colors for tying into the Factory Keyless? I printed off the sheet from here but it does not talk about the factory relays...
Please help!
mo12v
Posted: December 02, 2005 at 10:42 AM / IP Logged
Power LockWHITE/ D GREENBLACK 14 PIN CONNECTOR
Power UnlockSINGLE WIRE SYSTEMIN DRIVER KICK PANEL **
** Single Wire Door Lock System, WHITE/ D GREEN Found In The Connector At The Bottom Of The BCM.Chassis Ground Thru A 1.5K Ohm Resistor (Lock) And Chassis Ground Thru A 249 Ohm Resistor To Unlock.
RKE ModuleBODY CONTROL MODULE BEHIND DRIVER DASH
Motor LockORG/BLKGRAY 36 PIN CONNECTOR AT BCM *
Motor UnlockPNK/BLKGRAY 36 PIN CONNECTOR AT BCM *
Drv Door UnlockWHT/BLKGRAY 36 PIN CONNECTOR AT BCM *
OEM RelaysAT BCM
Circuit Type: Reversal Rest At Ground
MO
slicksam
Copper - Posts: 291
Posted: December 02, 2005 at 10:53 AM / IP Logged
another way you can get the doorlocks......listen to the relays that click when you activate the doorlocks.
once you find them(1 relay for lock and the other for unlock)
remove the relay and solder your doorlocks output from the remote starter to the left side of the relay(test this first) pin 85
Testing is the key
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
