2005 silverado using CA-520-A
watson0720
Posted: December 08, 2005 at 11:46 PM / IP Logged
can anybody tell me about the code alarm security system with remote start?  i can purchase it on the military base i am on but don't know if it is a good alarm or not!!
customak47
Copper - Posts: 164
Posted: December 12, 2005 at 1:22 PM / IP Logged
I quit using code alarm remote starters because of the chevy trucks in 1999. the second ignition relay on the code alarm harness would loop the ignitions through the relay and interrupt the retained accessory power function of the truck intermittently. I now use Ultrastart units and have very little problems with them. for the aftermarket keyless entry feature to work on that truck (2005) you either need a doorlock interface or the wiring diagram for the locks that includes cutting wires and installing relays in the door. you will also need an anti theft system bypass. DEI makes a nice all in one unit, but I cannot remember the model number, 456g I think. The ultrastart unit you would need would be a tl1250 or new 1270.
My rifle is my friend...
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
