2002 Accord, alarm/keyless entry
hbjosh
Posted: December 12, 2005 at 8:45 PM / IP Logged
2002 Honda Accord Special Edition keyless entry does not unlock anymore with new alarm system, before installation the unlock was working perfect.  Verified wires. Relay is triping, yet no unlock.  When attempting to unlock with factory remote makes noise in door but doesn't unlock either.  Is there a second wire that needs to be triped to cause unlock w/ factory alarm with new 3rd party one?
THIS IS JOSH <IJOSH>INFO
KarTuneMan
Platinum - Posts: 7,056
Posted: December 16, 2005 at 9:58 AM / IP Logged
Power Lock BLACK/ blue  -  passenger side fuse box
Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box.","HONDA, ACCORD, 2002, Power Lock");' rel="nofollow" href="http://www.directechs.com/directwire/wire_body.asp?action=select&yr=3437&product=Remote Start#">2002 Accord, alarm/keyless entry -- posted image.
Power Unlock orange  -  passenger side fuse box   2002 Accord, alarm/keyless entry -- posted image.
Sounds to me like you have a factory acctuator goin south.
They are fairly easy to replace....just contort you hands and wrists to bend backwards.....no problem
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
