GM-U7 & Heated Seats
supercruiser
Member - Posts: 17
Posted: December 29, 2005 at 3:16 PM / IP Logged
How would I go about getting the Crime Stopper GM-U7 module to activate heated seats in a 2005 Chev Suburban.  It says it supports heated seats but gives no details
Thanks Jeff
Water collects in low spots
Craig3708
Copper - Posts: 155
Posted: December 30, 2005 at 6:43 PM / IP Logged
I'm not sure about this model, but the model I use GM-SL will only turn on the heated seats on when the engine temp is at zero degrees or below.
Craig
Haku
Copper - Posts: 204
Posted: December 30, 2005 at 7:45 PM / IP Logged
The GMU7 works the same as the GM-SL.  When the temp is o (C) or 32(f) it will turn on the heated seats (on low setting) automatically.  No programming, or setting it...  It just does it (on supported vehicles).
Hak
Hak
Siemens Autostart
