ford e-250 2006 tach wire
slugger24
Posted: January 07, 2006 at 2:30 PM / IP Logged
Anyone have correct tach wire for ford e-250 2006.  I cant find a wiring diagram for 2006 and the WHITE/ pink wire listed for 2005 isnt working.  I'd prefer not to go to the fuel injectors.
mo12v
Posted: January 07, 2006 at 5:18 PM / IP Logged
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=6107&product=Remote%20Start
MO
jacqueslacombe
Copper - Posts: 124
Posted: January 08, 2006 at 3:37 AM / IP Logged
hi! cHECK a grernn/whithe wire attached to an harhess behind the fuse box   There is about 5 to 8 wire untaped  according to the astro chart ...
cocolaboy
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
