Siren negative output
romic00
Member - Posts: 21
Posted: January 18, 2006 at 7:16 PM / IP Logged
Hi i have a bulldog delux 500 remote starter and the output for the horn/siren is a negative wire. I have a siren from an alarm i had before and i am just wondering how can i wire it? In the manual it saysthat the wire is a negative 200ma output and should only be connected to the cars horn. How can i connect this siren? if i have to use a realy how do i wire it thx.
Mike M2
Platinum - Posts: 2,652
Posted: January 18, 2006 at 9:15 PM / IP Logged
Use a relay. 30 and 86 get 12V+. 85 goes to your 200ma negative horn output. 87 goes to the siren positive. Ground the siren negative.
Mike M2
Tech Manager
CS Dealer Services
auex
Platinum - Posts: 5,041
Posted: January 18, 2006 at 9:51 PM / IP Logged
Be aware that the wire in question is probably designed to honk the car horn. If you hook up a siren it will do the same, pulse the siren for a second-pause-repeat.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
romic00
Member - Posts: 21
Posted: January 18, 2006 at 10:59 PM / IP Logged
What do you mean is that bad? if i hook it up?
dualsport
Silver - Posts: 983
Posted: January 19, 2006 at 3:06 PM / IP Logged
It means the siren won't sound continuously when the alarm is sounding off, the way it's normally supposed to. Other than that, it won't harm anything.
If you don't mind the intermittent siren sound, then you could hook it up that way; it'd definitely be more distinctive so you can identify your car out of a sea of wails- Siren negative output -- posted image.
If there's really no other output from the alarm that has a continuous output, it wouldn't be hard to make up a circuit to stretch it out and make it continuous, but I'd check first to see if there's another output that comes on steady when triggered, and just use that.
dualsport
Silver - Posts: 983
Posted: January 19, 2006 at 8:10 PM / IP Logged
However it's done, make sure it unlatches after the alarm times out, or the neighbors may get restless and bust something-
dualsport
Silver - Posts: 983
Posted: January 21, 2006 at 2:02 AM / IP Logged
This takes an intermittent horn honk output (-) and outputs a steady 12V for a siren, by stretching out the on time. If the horn honks less than once a second, the R1 or C1 values can be increased to bridge the gap.Siren negative output -- posted image.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
