94 c2500 wiring
j.egray
Posted: December 25, 2002 at 8:06 AM / IP Logged
Going to be intalling a 552t on my 94 Chevrolet c2500 truck this weekend.  I do know how to test for all my wires but thought I would post here to see if any one had a wiring diagran to make this go faster.  Thanks!!
Moderator - Posts: 12,488
Posted: December 25, 2002 at 8:25 AM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow or purple    |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
|       POWER LOCK|lt. blue            |*1 |either door boot            |
|     POWER UNLOCK|BLACK/ red           |*1 |either door boot            |
| PARKING LIGHTS +|brown               |   |switch or fuse panel        |
|       HEADLIGHTS|yellow              |+  |at switch                   |
|     DOOR TRIGGER|white               |-  |light switch                |
| DOME SUPERVISION|use door trigger    |   |                            |
|       TACHOMETER|white *2            |   |ECM *3                      |
|       BRAKE WIRE|white               |+  |at brake pedal switch       |
|     HORN TRIGGER|black               |-  |at column                   |
|           WIPERS|purple              |+  |steering column             |
|  LF WINDOW UP/DN|dk. blue - brown    |A  |at drivers door switch      |
|  RF WINDOW UP/DN|light blue - tan    |A  |drivers door or boot        |
|  LR WINDOW UP/DN|green - purple      |A  |drivers door or boot        |
|  RR WINDOW UP/DN|lt. grn - pur/wht   |A  |drivers door or boot        |
Notes:
*1 5 wire (type C) on the two door models, and positive trigger (type A) on the four door and keyless entry models.  *2 Tach wire on the 6.5 Diesel is white at the instrument cluster. Diesel wait to start wire is dk. blue (+) located at the instrument cluster.  *3 ECM located behind the glove box.
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
