door locks on a 1993 honda accord wagon
bdby1977
Member - Posts: 6
Posted: January 25, 2006 at 9:45 PM / IP Logged
i need a doorlock diagram for a 93 honda accord wagon so i can hook up an after market alarm with remote start can some one assist  me? thanks jason p.s. i was told about a plug under back seat with blue tape or in driverside kick panel but no plug. now under left front seat i found a 3 prong plug with blue tape could that be it?
tjdurham
Copper - Posts: 180
Posted: January 25, 2006 at 10:17 PM / IP Logged
green\white and yellow\white
dr kick under footrest under all wires it should be there if not under back seat
tj
jacqueslacombe
Copper - Posts: 124
Posted: January 26, 2006 at 2:00 AM / IP Logged
Well check in the harness going on the floor on the driver side the LOCK wire is BLACK/ white and the unlock wire is BLACK/ red  those are (-) trigger
iskidoo
Silver - Posts: 1,046
Posted: January 26, 2006 at 2:08 AM / IP Logged
DEI notes:
HONDA, ACCORD, 1993, Power Lock
Locate the large harness in the lower below the carpet in the drivers kick panel. Near the foot rest you will notice a piece of blue tape attached to the harness itself. Reach around to the underside of the blue tape to locate a 2 pin gray plug with the lock and unlock wires attached to the plug.
The station wagon uses GREEN / WHITE for lock and yellow/white for unlock. These wires are found either in the drivers door harness or under the rear seat.
Steve G
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
