Best bypass module Honda Accord 2004 ?
viptime
Member - Posts: 33
Posted: January 26, 2006 at 9:47 PM / IP Logged
What bypass module should I use  Honda Accord 2004?
555U, 555i, 555h, 555HW, HODL2, or PKH3
I found all of  the above units advised for this car
Which one is best what are the advantages?
All I want it to do is to substitute the key
Thank you
Best bypass module  Honda Accord 2004 ? -- posted image.
My ability to fix things is only superseded by ability to make it worth in the process
autotech mobile
Member - Posts: 34
Posted: January 26, 2006 at 10:22 PM / IP Logged
I have been using the new 556H which replaces the 555H.
Moderator - Posts: 12,488
Posted: January 26, 2006 at 11:53 PM / IP Logged
I use the PKH3 for this. Make sure that you have ALL keys to program this incase on e of the keys doesn't program properly.
tjdurham
Copper - Posts: 180
Posted: January 27, 2006 at 7:49 AM / IP Logged
Exactly the pkh3 is the best DEI ones have some issues
tj
mike swanson
Copper - Posts: 290
Posted: January 27, 2006 at 9:30 AM / IP Logged
CAN SL works the oem alarm, trunk, door locks and tach all with the data wire
au5599
Copper - Posts: 95
Posted: January 27, 2006 at 10:38 AM / IP Logged
I use pkh3 for these. Never had an issue yet. I cant say anything about dei cause I do not use them.
viptime
Member - Posts: 33
Posted: January 27, 2006 at 6:36 PM / IP Logged
thank you everyone
