2003 ford f350 diesel tach signal
jmacf14
Copper - Posts: 160
Posted: January 27, 2006 at 7:50 PM / IP Logged
Hi guys its me again! every thing went great on the install (especially the door locks!! thanks again!), except im not getting a proper tach signal. the vehicle info that i got was for a green or white wire at a large connector under the air intake duct. guess what i cant find the connector! so I called a friend and he said that it should be a GREEN / WHITE wire at the harness behind the park brake release. the only thing that i found there is the fuse box with several connectors on it.  does anyone know for sure where i can find a good tach signal? Im dense, so please be very descriptive! keep in mind that this is a 2003 ford F350 superduty powerstroke diesel. thanks again for your help!!
jmacf14
mo12v
Posted: January 27, 2006 at 8:06 PM / IP Logged
If you pull the Fuse Box out  ( 4 10mm screws )... Look behind there should be a 5 Wire Harness taped to the Main harness.  These 5 wires are cut off with NO Ends.
GREEN / White should be TACH
MO
jmacf14
Copper - Posts: 160
Posted: January 27, 2006 at 8:15 PM / IP Logged
 awesome!! thanks for the quick reply!! ill post again and let you know if it worked!!
jmacf14
jmacf14
Copper - Posts: 160
Posted: January 28, 2006 at 5:48 PM / IP Logged
 well that tach signal worked awesome! thanls again for all of the help!!
jmacf14
Monday, January 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
