1996 Subaru Legacy wagon, Lock wire ?
12vbattery
Member - Posts: 17
Posted: January 30, 2006 at 5:58 PM / IP Logged
iv installed the alarm the only thing not working is the locking of the doors.. the table on this site says the WHITE/ red is the lock wire but it doesnt work only the white wire for unlocking works please help is there a wire i need to cut so the WHITE/ red wires will work ? or is there some sort of relay i need to add-on or perhaps locating the central lock module which i have no idea where that is...
jmacf14
Copper - Posts: 160
Posted: January 30, 2006 at 6:24 PM / IP Logged
how are you making your connections? t-taps, or what? the WHITE/ red is the correct wire.and you say that it unlocks okay?
jmacf14
12vbattery
Member - Posts: 17
Posted: January 30, 2006 at 7:01 PM / IP Logged
yea its a tap to the lock WHITE/ red wire doesnt seem to work it only works for the unlock white wire any suggestions
cntrylvr79
Silver - Posts: 582
Posted: January 30, 2006 at 8:38 PM / IP Logged
Yeah if you're using ttaps... Don't.  Splice the wires.
Cause I'm So white and nerdy...
First Class Certi-fried installer
jmacf14
Copper - Posts: 160
Posted: January 30, 2006 at 9:12 PM / IP Logged
I would solder all of your connections, that will probably fix your problem!
jmacf14
12vbattery
Member - Posts: 17
Posted: January 30, 2006 at 9:21 PM / IP Logged
but why isnt it locking the door am i tapping the wrong WHITE/ red lock wire? the white unlock wire was at the kicker panel the WHITE/ red wasnt on the same connecter harness so i just tapped the white unlock wire of the door connector that leads out to the side of the car to the drivers door, the WHITE/ red was on another connector i used a meter to test WHITE/ red lock wire no values showed up. where is the WHITE/ red wire suppose to be? .. so annoying everything but the lock works.. the keyless still works unlock/lock.. just need to fine that lock wire for the alarm. 1996 Subaru Legacy wagon, Lock wire ? -- posted image.
Thursday, January 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
