Strobe Lights
crcustoms45
Member - Posts: 29
Posted: February 15, 2006 at 9:30 PM / IP Logged
2003 F150 with a Viper 791XV
recently installed whelen 90 watt strobes with intention to catch your eye at shows and draw attention to triggered alarm in a parking lot
im looking for a way to build an output from the alarm to
A> turn on strobe lights by remote
B>activate strobes when alarm is triggered
i have installed several of these alarms, and im pretty sure there is not a constant switched output.  the strobe lights turn on and off with a switch
there is a way to do this, just draws a blank right now. thanks in advance
Chris
CRCustoms
mrcllusb
Copper - Posts: 489
Posted: February 16, 2006 at 4:56 AM / IP Logged
If i'm thinking correctly,you could wire it into another channel on your alarm that will be activated by a channel on the remote.You would need a relay wired into that channel to create a switch point..
"ole blake"
Chris Luongo
Platinum - Posts: 3,746
Posted: February 16, 2006 at 6:59 AM / IP Logged
Did you install the Viper yourself? Do you have the install manual, as well as any extra wiring plugs that weren't used in the original install?
You'll need to be familiar with relays to do this, but you can read all about them on this site, off to the left.
Anyway, get the Viper's install manual, and read about the "channel 4" auxilary output. You want to go into programming and set it to "latched, reset with ignition."
That means that one push of the remote turns on the output forever, and another push turns it off.......but as soon as you turn on the key, it automatically shuts off.......this way, you don't get pulled over if you forget to shut off the strobes.
Anyway, that output is only a weak ground.....just enough to trigger a relay and that is all.........use the output to trigger the relay, and the relay to apply power to the strobes:
85, 87: FUSED 12 volts
87A: not used
86: aux output from alarm
30: + output for strobes.
As far as making the strobes flash when the alarm is triggered.......
Find the wire going from the alarm to the siren...I think it's brown? Cut it in half.
Connect two heavy (at least 6-amp) diodes to the "alarm" side of the wire..........connect the other end of one of the diodes back to the siren........connect the other diode to the strobes.
This will also cause a small strobe flash with arm and disarm, when the siren chrips, but that shouldn't be bothersome.
mrcllusb
Copper - Posts: 489
Posted: February 16, 2006 at 7:08 AM / IP Logged
I thought i was right in that it could be done that way...
"ole blake"
crcustoms45
Member - Posts: 29
Posted: February 24, 2006 at 6:55 PM / IP Logged
thanks man, your advice worked perfectly.  i had figured out the majority of it but i didnt know about the programinng the output.  wasnt sure what latched ment.
Chris
CRCustoms
