2004 Ford Mustang alarm/remote start
Anderson463
Member - Posts: 21
Posted: February 20, 2006 at 10:42 AM / IP Logged
I just bought a Auto-page RS-720LCD remote and Alarm combo. what I am wondering is there a bypass that I need to buy for the cars factory alarm? also if anybody has any tips on what to do and what not to do that would be greatly appreciated!!!!
oh and is there any better wiring diagram better then the one found on this site?
thanks again
~Paul
mustangfoo
Silver - Posts: 371
Posted: February 20, 2006 at 12:23 PM / IP Logged
as soon as I get home later today, I will send you the bypass module and the wire diagram, cause everything is on my home pc and am somewhere at the moment.
another-kelly
Silver - Posts: 618
Posted: February 20, 2006 at 9:46 PM / IP Logged
FORD / MUSTANG / 2004
12volts yellow & lt. GREEN/ purple  +  ignition harness
Starter WHITE/ pink  +  ignition harness
Second Starter N/A
Ignition RED / lt. green  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory gray / YELLOW and RED / black  +  ignition harness
Second Accessory BLACK/ lt. green  +  ignition harness
Keysense BLACK/ pink  -  ign harn, 26 pin plug, pin 9 at GEM
Notes: The GEM (Generic Electronic Module) is located above the driver kick panel.
Power Lock lt. green  +  20 pin plug, pin 20 at GEM
Power Unlock purple  +  20 pin plug, pin 18 at GEM
Lock Motor RED / white  5wi 20 pin plug, pin 9 at GEM
Unlock Motor RED / orange  5wi 20 pin plug, pin 7 at GEM
Parking Lights+ brown  +  26 pin plug, pin 7 at GEM
Parking Lights- WHITE/ black  -  26 pin plug, pin 11 at GEM
Hazards same as turn signals
Turn Signal(L) lt grn/wht(F), lt grn/org(R)  +  steering column
Turn Signal(R) wht/lt blu(F), org/lt blu(R)  +  steering column
Reverse Light BLACK/ pink  +  26 pin plug, pin 20 at GEM
Door Trigger yel/black (L), gray/red (R)  -  20P plg, pin 13 & 5 at GEM
Notes: Use yellow/black for the driver door trigger and gray/red for the passenger door. Use both wires and diode isolate each from the GEM module, refer to DirectFax document 1076 for wiring information.
Dome Supervision BLACK/ white  +  20 pin plug, pin 3 at GEM
Trunk/Hatch Pin BROWN / white  -  12 pin plug, pin 3 at GEM
The hatch pin needs to be diode isolated from the GEM module. Refer to DirectFax document 1076 for wiring information.
Hood Pin N/A
Trunk/Hatch Release pink/lt. green  -  26 pin plug, pin 25 at GEM
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm dk. GREEN/ purple  -  20 pin plug, pin 16 at GEM
Disarm No Unlock see factory alarm disarm
Tachometer NOT red or WHITE/ lt. blue  ac  ignition coil or coil pack
Wait to start N/A
Brake Wire RED / lt. green  +  brake pedal switch
Parking Brake purple / YELLOW or lt. blu/blk  -  12 pin plug, pin 4 at GEM
Horn Trigger yellow/lt. green  -  26 pin plug, pin 12 at GEM
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PATS
Part #: 555FW
Alternate Part1 #: 556UW
mustangfoo
Silver - Posts: 371
Posted: February 20, 2006 at 11:47 PM / IP Logged
looks the same as mine
Anderson463
Member - Posts: 21
Posted: February 22, 2006 at 10:28 AM / IP Logged
thanks guys! that will help out alot!
Anderson463
Member - Posts: 21
Posted: February 25, 2006 at 3:21 AM / IP Logged
I am have another question.... I bought a Bypasskit Model PKF1 but I am unsure how to hook it up. it says that I need to hook some wires up to the ECM TX and RX. I know what TX and RX stand for but where I can I hook these wires up? I am stumped for now. PLEASE HELP! also where do I hook the  Ground When running wire from the bypasskit to?
I will be check back later. thanks again!
~Paul
Anderson463
Member - Posts: 21
Posted: February 26, 2006 at 9:51 AM / IP Logged
never mind.... I fingered it out
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
