457g?
Mr_Fusion
Copper - Posts: 113
Posted: March 01, 2006 at 9:59 AM / IP Logged
I have a couple of questions regarding the 457G
1. When arming or disarming, does the 457G flash the parking lights??
2. When disarming at night, will the 457G activate perimeter lighting??
3. When arming or disarming, will the 457G sound the horn??
4. When disarming, will the 457g activate the dome lights??
These questions are assuming the car is programmed to activate the above features using the factory remote.
Ravendarat
Platinum - Posts: 2,806
Posted: March 01, 2006 at 10:15 AM / IP Logged
OK
1. Parking light flash is a seperate option built into the alarm and/or starter so it must be hooked up off that unit not the 457.
2. Unsure
3. Once again, a feature on the unit usually although I believe if the vehicle is set to honk on a single pulse it will honk when arming. It does not honk on disarm.
4. Yes it will do dome light on disarm.
What vehicle is this for. I gave generic answers but it wont do it on all vehicles. On some vehicles it will only do passlock or passkey and nothing else.
customak47
Copper - Posts: 164
Posted: March 01, 2006 at 10:59 AM / IP Logged
no it does not flash park lights, but you may be able to change factory custom settings in instrument cluster to flash park lights on arm/disarm, but will not turn on during remote start at all.
yes will turn on perimeter lights
not normally, but same as q's 1, you may be able to change factory settings
yes dome superv. works
My rifle is my friend...
Mr_Fusion
Copper - Posts: 113
Posted: March 02, 2006 at 10:28 AM / IP Logged
Thank you for the replies!!
bazzgazm
Copper - Posts: 113
Posted: March 02, 2006 at 8:01 PM / IP Logged
actually, new units will not operate perimeter lighting.
that is being fixed
