Keyless Entry, 1986 Corvette?
dj hellfire
Member - Posts: 39
Posted: March 03, 2006 at 9:19 PM / IP Logged
Anyone installed keyless entry on an 86 Vette or similar?  I was trying to figure out the door lock circuit to wire into the keyless entry module.  I looks like I will have to cut a couple of the Vettes lock motor wires and connect each end to a wire on the keyless entry module.  Anyone familiar with this?  It seems to use 5 wire door lock circuits at each door activated by lock motors, no relay.
mo12v
Posted: March 03, 2006 at 9:31 PM / IP Logged
Power LockLIGHT BLUEDRIVER KICK PANEL, MUST TEST
Power UnlockBLACKFROM PASSENGER SWITCH
Reversal Rest At Ground Door Locks
MO
