Ford remote start systems?
mville656
Member - Posts: 9
Posted: March 04, 2006 at 8:34 PM / IP Logged
I am interested in installing a remote starter in my 2006 Ford Five Hundred.  I was considering using the Ford Silver system because I don't need an alarm.  What my question is...Do you still need to "tap" into the door lock wiring or does the Ford system use the existing keyless entry?  In otherwords can I just program the new Ford key fobs the same way you would program a replacement or will I have to do a complete install and splice some door lock wires?
Thanks,
Mike
KarTuneMan
Platinum - Posts: 7,056
Posted: March 05, 2006 at 1:45 AM / IP Logged
The "OE" stuff might be a tad bit easier to install........butone thing I guarantee you won't like. The range!
It should be "plug and play" BUT....might not be! Get a unit with some range. Thre are plenty to choose from
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=6138&product=Remote%20Start
Fastlearner
Silver - Posts: 346
Posted: March 05, 2006 at 2:35 AM / IP Logged
see how far your keyless will go. decide if your happy with that distance. If not get an aftermarket.
mobilecustoms
Silver - Posts: 397
Posted: March 05, 2006 at 7:07 AM / IP Logged
Ford makes a powercode code alarm system. It comes in gold, silver and bronze. It is made by code alarm so.. its not that great. I like the DEI stuff. The range on the Ford is about 500 feet. It is a very expensive system. You are better off going to Best Buy or circuit city and getrting a viper 130 or something. I dont think it is worth the money.
Platinum - Posts: 12,488
Posted: March 05, 2006 at 10:11 AM / IP Logged
To add to this, it's not just a plug and play either. There are about 50 wires to hook up on the OEM remote starter's/keyless entry/security systems.
john ogrady
Copper - Posts: 82
Posted: March 05, 2006 at 9:34 PM / IP Logged
I did  an install of remote car starter in a 05 Ford Five Hundred.I used an aftermarket and i tapped in the lock and unlock wires.I did research the Ford and their is a lot more to the install.
mville656
Member - Posts: 9
Posted: March 05, 2006 at 9:40 PM / IP Logged
Thanks everyone I think you helped my decision.  I have decided to go with something other that the Ford system.  I'm sure everyone has their personal preferences but I am open for suggestions on brands/models.  I don't want an alarm, but a small 2 way would be nice.  I don't like the big LCD screens that some come with.  I was looking at the Audiovox PRO 900 or the APS 786T.  Before anyone yells, I know that the 786T has an alarm, but I was not intending on using it.  Any feedback on those two models or does anyone have anything similar they suggest?
Thanks,Mike
mobilecustoms
Silver - Posts: 397
Posted: March 06, 2006 at 4:52 PM / IP Logged
i like the dei viper 591- just keyless and start
john ogrady
Copper - Posts: 82
Posted: March 06, 2006 at 7:51 PM / IP Logged
The Audiovox 786T is a combo unit remotestart/alarm.I would use the Audiovox 686T which is just a remote start with lots of options like illuminated entry and horn alert for the remote start signal.The letter " T " on the Audiovox model means it has a telematics port.You can get a satellite module which plugs into the remote start module and allows you to unlock the doors and activate your remote start from any telephone.There is also no monthly fees with module also.
mville656
Member - Posts: 9
Posted: March 06, 2006 at 11:59 PM / IP Logged
What other parts am I going to need to override the factory transponder?  I think I have decided on the Audiovox 686
Mike
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
