2005 nissan frontier remote start
deck60
Posted: March 07, 2006 at 9:48 AM / IP Logged
has any one put a remote start on one of these  is there anything i will need besides a few relays  and maby some diodes any help will be appricated
xscash
Copper - Posts: 317
Posted: March 07, 2006 at 8:18 PM / IP Logged
MODEL YEAR(S)
 FRONTIER  2005 -
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   NO INFORMATION AT THIS TIME!!!
 PART  COLOR LOCATION
 12 VOLT CONSTANT  GREEN (+)   IGNITION SWITCH HARNESS
 STARTER GRAY (+) See NOTE *1  IGNITION SWITCH HARNESS
 STARTER 2 LIGHT GREEN (+) See NOTE *1 IGNITION SWITCH HARNESS
 IGNITION 1 WHITE/ GREEN (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 RED (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 GREEN/ YELLOW (+)  IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) GRAY (+)  IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
 POWER LOCK LIGHT GREEN to PURPLE (TYPE B)  IN DRIVERS KICK PANEL or BCM, PIN 45, See NOTE *2
 POWER UNLOCK WHITE to LIGHT GREEN (TYPE B)  IN DRIVERS KICK PANEL or BCM, PIN 46, See NOTE *2
 DOOR TRIGGER See NOTE *3  @ BCM, See NOTE *2
 DOMELIGHT SUPERVISION BROWN (-)  @ BCM, Pin 63, See NOTE *2
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BROWN (-)  @ HORN SWITCH in STEERING COLUMN
 TACH Any wire NOT WHITE/ GREEN  @ Any FUEL INJECTOR
 WAIT TO START LIGHT N/A
 BRAKE YELLOW (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  RED / WHITE to GRAY (-)  IN DRIVERS KICK PANEL or BCM, Pin 7, See NOTE *2
 ANTI-THEFT No Information at this time!!!
 EXTRA INFORMATION
 NOTE *1 When Installing a REMOTE STARTER, you MUST use BOTH Starter #1 and Starter #2 wires. Both wires must be connected to the STARTER/CRANKING Output wire from the Remote Starter or the vehcile will NOT Remote Start when the Engine is cold. NOTE *2 the BCM (Body Control Module) is located to the RIGHT of the STEERING COLUMN. NOTE *3 this vehicle has 4 Door Pin Trigger wires, the DRIVERS Door is a GRAY (-) Pin 47, the PASSENGER Door is a LIGHT GREEN (-) Pin 12, the DRIVERS REAR Door is a PINK (-) Pin 48 and the PASSENGER REAR Door is a BLUE (-) Pin 13. All wires are at the BCM. When connecting to an ALARM SYSTEM, use all 4 DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM
