06 325i remote start/alarm
mkaudio17
Member - Posts: 38
Posted: March 15, 2006 at 4:47 PM / IP Logged
Can it be done, my local dealer said it cannot, i do not believe him, anyone have any info on the car? Tech sheets?, all i got is up to 2004 on directtechs, thanks
Professionalism.
Twelvoltz
Platinum - Posts: 2,384
Posted: March 15, 2006 at 4:57 PM / IP Logged
The car is CAN bus and I do not believe there is any interface available.
Yet.
mkaudio17
Member - Posts: 38
Posted: March 16, 2006 at 10:38 AM / IP Logged
any other info, the dealer said that it is rolling code, if there is a transponder a U wont just work>?
Professionalism.
xscash
Copper - Posts: 317
Posted: March 16, 2006 at 12:00 PM / IP Logged
here is the link  and the ews system is a pain sometimes...good luck,   XS
http://techservices.audiovox.com/Print.aspx
Twelvoltz
Posted: March 16, 2006 at 12:20 PM / IP Logged
XS...That link isn't working for me as I do not have a l/p for the audiovox tech site. Anyway we could get you to do a screen dump of it?
And...if you really have excess cash, I will give you a paypal address you could send some to. ;)
xscash
Copper - Posts: 317
Posted: March 16, 2006 at 6:27 PM / IP Logged
here you go!06 325i remote start/alarm -- posted image.
509144: 2006 BMW 325I 4DR SEDAN
 Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  RED / WHITE  (+)  RADIO HARNESS
 Accesory  VIOLET/WHITE  (+)  RADIO HARNESS
 Ground  BROWN  (-)  RADIO HARNESS
 Power Antenna  WHITE  (+)  RADIO HARNESS
 LF Speaker (+)  YELLOW/RED
 LF Speaker (-)  BROWN / ORANGE
 RF Speaker (+)  BLACK/ RED
 RF Speaker (-)  BROWN / ORANGE
 LR Speaker (+)  YELLOW/BLACK
 LR Speaker (-)  BLACK/ ORANGE
 RR Speaker (+)  BLUE/BLACK
 RR Speaker (-)  BROWN / ORANGE
 Radio Security  YES
 Security
 Battery  RED / GREEN  (+)  IGNITION SWITCH HARNESS
 Ignition 1  GREEN  (+)  IGNITION SWITCH HARNESS
 Starter 1  BLACK/ BLUE  (+)  IGNITION SWITCH HARNESS
 All Door Trigger  RED / BLUE  (+)  IN PLUG AT WHITE MODULE BEHIND GLOVEBOX
 Trunk Trigger  WHITE/ BROWN  (-)  IN HARNESS IN DRIVERS KICKPANEL
 Hood Trigger  VIOLET/GREEN  (-)  AT MODULE BEHIND GLOVEBOX
 Parking Lights  RIBBON CABLE  (+)  AT VEHICLE LIGHT SWITCH
 Convenience
 Headlights-Lo  YELLOW  (+)  AT VEHICLE LIGHT SWITCH
 Wipers-Lo  BLACK/ GRAY  (-)  IGNITION SWITCH HARNESS
 Trnk Release  GRAY/RED  (-)  AT TRUNK RELEASE SWITCH
 Remote Start
 Ignition 2  VIOLET  (+)  IGNITION SWITCH HARNESS
 Accessory 1  VIOLET  (+)  IGNITION SWITCH HARNESS
 Anti-Theft Type  BMW EWS® VEHICLE IMMOBILIZER
 Anti-Theft Descript  THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
 Key Sense  RED  (-)  IGNITION SWITCH HARNESS
 Tachometer  BLACK  (-)  ROUND BLACK PLUG ON PASSENGER SIDE FIREWALL
 Speed Sense  WHITE/ BLUE  (AC)  IN HARNESS FROM GAUGES
 Brake Lights  BROWN / WHITE  (+)  AT SWITCH ABOVE BRAKE PEDAL
 Reverse Lights  BLUE/RED  (+)  IN HARNESS AT LIGHT
 Modules
 WIRE  LOCATION
 Please select another category
 Doorlocks/Windows
 Power Unlock  BLUE/RED  (-)  AT MODULE BEHIND GLOVEBOX
 PowerLock  WHITE/ BLACK  (-)  AT MODULE BEHIND GLOVEBOX
Twelvoltz
Posted: March 16, 2006 at 6:38 PM / IP Logged
NICE!
DEI only lists to 2004 on the web based tech sheets for the 3 series. Looks like I'm gonna have to get myself an Audiovox pass.06 325i remote start/alarm -- posted image.
Thanks for the info.
mkaudio17
Member - Posts: 38
Posted: March 18, 2006 at 6:50 PM / IP Logged
Awesome, thanks
Professionalism.
