02 Caravan power window problem
auto_sec_paul
Member - Posts: 6
Posted: March 28, 2006 at 6:34 PM / IP Logged
Hey guys, just finished an 02' Caravan remote start install and now the power windows are acting weird-by weird I mean they are closing half way, stalling, then closing the rest of the way with the van running, but seem to be okay when only the ignition is on but without the engine running....I have seen this problem before but can't remember what was done to correct the situation.
I hooked up Accessory wire with ignition and i'm thinking this may be the problem after reading some of the other posts on this subject.
Has anyone else seen this problem before?
sparkie
Platinum - Posts: 2,061
Posted: March 28, 2006 at 9:01 PM / IP Logged
Did you hook up the second starter wire? It is violet/brown and needs a 180 resistor to ground during crank. Check to make sure that you have plugged in all the connectors of the BCM completely. Make sure that you haven't used the battery wire going to the ignition switch for main power. It is better to run a fused line off the battery.
sparky
auto_sec_paul
Member - Posts: 6
Posted: March 30, 2006 at 5:05 PM / IP Logged
Hooked up second starter wire, all wires were correct, and 12 volts power straight to battery.......it was actually the relay that was giving me some hassles....
Instead of having the 180 ohm resistor inline to ground, I had it going to the second starter wire......so I just changed it to the ground wire off the relay like you suggested and voila, it worked like a charm........Thanks for the info man..
Paulie.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
