2001 f-150 door lock switch
carstereoman
Member - Posts: 48
Posted: March 31, 2006 at 10:09 AM / IP Logged
Anybody got wiring schematics for Ford F150 door lock switch? I'm trying to use the factory switch to run an aftermarket actuators.
Platinum - Posts: 12,488
Posted: March 31, 2006 at 10:24 AM / IP Logged
POWER LOCK|pink / YELLOW
POWER UNLOCK|pink/green
Non-keyless versions are 5 wire located in the drivers door harness. Keyless versions are negative trigger located in a gray molex plug to the right side of the steering column . If your adding actuators then use this diagram
qdaddy
Copper - Posts: 133
Posted: April 01, 2006 at 1:23 AM / IP Logged
i have does this before chevy ford there are two wires at factory motors cut them tie into aftermarket actuators that is if you are replacing bad factory actuators
