microc2003 alarm
tnez2
Member - Posts: 26
Posted: April 04, 2006 at 12:07 PM / IP Logged
 Hi I have a microc2003 remote start/alarmon a 2001 ford ranger. the problem i am having is that the keyless unlock somtimes wont unlock the doors it seem that it wants to but it wont. and it seems that it only will do this when the alarm goes off, it will unlock if i press the auto start and start the truck and then press the the unlock button. is this normal .  thanks
mo12v
Posted: April 04, 2006 at 7:24 PM / IP Logged
Ford's G.E.M. May Drop A Low Signal Across The Dome Light And In Most Cases Cause A False Trigger.
To Eliminate This Cut the Door Pin Trigger Wires At The G.E.M. And Insert A One-Amp Diode With Band Side Faceing Doors.
Make Your Isolated Connection On The Door Pin Side.
The GEM (Generic Electronic Module) Is To The Left Of The Radio.Door Pin Wires:YELLOW/BLACK (DR), GRAY/RED (PS)
Also, Be sure you are Waking the G.E.M. everytime......( Bad Connection ??)
.To Wake Up The G.E.M Send A Negative Pulse To The YELLOW/BLACK Driver Door Pin Wire With The Unlock Pulse. Diode Isolate Cathode Band Side Of Diode Faces Away From Vehicle Wires. YELLOW/BLACK Found At The Central Security Module Behind Dash Panel, RH Side.
MO
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
