XM Delphi Ignition On
Joe Neal
Copper - Posts: 113
Posted: April 08, 2006 at 8:24 PM / IP Logged
2005 Trailblazer:
Anybody have a way of keeping the XM Delphi Unit ON after Ignition is turned OFF??
Tried DEI Timer using Negative Trigger @ Ignition Accessory wire, but Timer is NOT quick enough to keep XM Delphi ON.
Any other suggestions is GREATLY appreciated
Hornshockey
Silver - Posts: 520
Posted: April 08, 2006 at 8:59 PM / IP Logged
I'm assuming you just want it on the same as the radio, until you open a door. If this is what you want, check the left side of the page, under relays/special applications. The setup for Retained Accessory Power will do what you need. This site is awesome!
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
